 How to set TMSJL2532A?
electricdream Posted - 11/14/2014 : 09:52:28
Hi technicals.
I have 10 TMSJL2532A eproms to program with Willem Programmer Q-4X usb.
Binary files that I want to insert in these eproms are the Atari 2600 games(4k max).
The eproms are empty and checked by the blank check, and some I even deleted with eproms eraser (21 minutes). I also use the power supply as specified by the USBPrg program.
I select: TMS2532JL as device(is the same TMSJL2532A?)
But when I want program them gives me the following error:
write failed, address = 0x00000, 0x78 buffer = device = 0xff.
What is wrong? I need to do a particular setting?
Thanks.
anniel Posted - 12/13/2017 : 08:45:20
Originally posted by ilpaninaro
Same problem...i need to write tms2532A eprom but i can't...
i see 2532 only read...
It's not possible write this eprom?
Maybe with an algorithm update. Do you have the datasheet?
ilpaninaro Posted - 12/13/2017 : 07:11:51
electricdream Posted - 11/16/2014 : 09:25:19
Another question:
The M2708F1 what eprom correspond including those supporting the GQ-4x?
