 GQ-3X ID PROBLEMS, READING PROGRAMING..
fox_el_negro Posted - 04/27/2009 : 23:31:31
this is the chip and some others like the mx29lv160, t28f160
53.84 KB
the probles is wen i select the rigth configuration the programer dont recognice the chip
62.04 KB
if i select another configuration then the id shows corect!!!
65.86 KB
this is mi programer and configuration!!
88.15 KB
whit the sst39vf160 configuration the chip reads ok butt cant erase or program the chip...
any idea?
PD: also have same problem whit mx29lv160
PD: and the intel chip t28f160 shows id ok and reads ok butt cant erase or program on it!!!!!
ZLM Posted - 05/04/2009 : 00:03:58
Tested the MX29LV160 with following line:
Name="MX29LV160CB(16bit)",ID="C22249",Class="SST39VF1601",Category="FLASH",MFG="Macronix",Speed="5",Adapter="TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
fox_el_negro Posted - 05/02/2009 : 22:44:02
works flawles on the amd chip butt the macronix, donot shows id, only wen i select the sst39lvxx it shows id
ZLM Posted - 04/29/2009 : 19:32:29
0 - For this particular chip AMD29LV160 you do not need buy another adapter.
1 - Yes. With this adapter line it should be able to work correctly.
2 - No. The USB Willem programmer JTAG currently is for CPLD device only.
fox_el_negro Posted - 04/29/2009 : 10:07:54
you are rigth !!!!!!!
i just check the correct adapter it shows all the brand tsop i cant program!!!!!
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3102
tanks!!!!!!!!
it jumps 3 questions!!
0- i need to buy the adapter?
1-whit the comand lines you gaveme i can program this chips? (intel t28fxx mx29lvxx am29lvxx) 8 bit chips or just the (amd)
2- can i use the usb willem programer to jtag a modem or fta device?
(this one is not important but i just want to ask)
tanks 4 u time!!!!!!!!!!!!
ZLM Posted - 04/28/2009 : 22:16:49
The adapter is not correct. The software for this chip is indicated 8 bit mode adapter. But you used 16 bit mode adapter.
To use 16 bit adapter, plese add following lines into devices.txt
Name="AM29LV160DB(16bit)",ID="012249",Class="SST39VF1601",Category="FLASH",MFG="AMD",Speed="5",Adapter="TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
