 Cant Burn
scar Posted - 01/04/2012 : 20:14:21
I am trying to burn a 27C010 32pin eprom, and in the program I keep on getting this
img404.imageshack.us/img404/647/willem.jpg
I have a 12v PSU connected and all that so it cant be the power, and I have the device securely connected, and the eprom is snug in the zif socket. The jumpers are set right and all that. I do not know what is wrong.
scar Posted - 02/21/2012 : 14:35:26
Ok, the Parallel port needed to be switched to EPP and it now writes chips. But I have normal eproms and it has no trouble writing to the same chip, I don't know if its burning right
scar Posted - 02/21/2012 : 14:19:20
I tracked down an old Toshiba laptop running Windows 98 and installed the software, the hardware checksout except for the VPP light. I try to burn a chip (27C010) and it gives me this error message
Error at 0x00000A Chip= 0x00 buffer 0xFF
scar Posted - 02/11/2012 : 11:17:42
I have it installed in XPmode which is virtualized Windows XP and its still giving me guff.
scar Posted - 02/05/2012 : 10:24:11
I have the hacked .dll to allow it to work on W7 64Bit. It starts up fine. I am going to do a test, I have a TSOP40 Adapter, and I will try and write a TSOP40 chip using the adapter.
ZLM Posted - 02/03/2012 : 22:29:50
The dual power willem drivewr only works on XP or earlier version windows.
scar Posted - 01/23/2012 : 14:41:59
I am running the driver in compatibility mode, on top of that I used it in Windows 7s XP mode thing, and got the same result.
ZLM Posted - 01/22/2012 : 23:39:47
check the confirm the driver is installed. The driver only works WinXP or earlier version windows. Also, check the data cable is a good and correct.
scar Posted - 01/09/2012 : 16:20:14
The only light that wont power on on the burner is the VPP, the others light up and the power light is Orange.
scar Posted - 01/09/2012 : 14:05:11
It still says "Check Power and Connection"
ZLM Posted - 01/09/2012 : 10:07:34
Try to do a self testing, see if you can find anything:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1097
scar Posted - 01/05/2012 : 14:55:47
I just noticed on the thing, ICSP is in red lettering and none of the other chips have that that I have checked. Am I missing something?
