 Programming Car Mileage through Eeprom
ecumotic Posted - 12/10/2012 : 21:34:07
hello, I recently purchased a automotive mileage corrector tool called "Digimaster 3". according to its instruction, i have tried to change the mileage of a HONDA FIT year 2008. The techniques i have used is to solder several wires to pinout locations on the dashboard and read and corrected the mileage.
However after the process, when i inserted the instrument cluster back into the car, i noticed some problems with the tacho and fuel gauge needles. It vibrates slightly and seems to be erratic.
I have gone through some online information and what i have been able to gather is that maybe the EEPROM has been damaged ( physically or software). so now my dashboard is not functioning. I have tried to put back the original files into the eeprom again, but it has worsened my situation.
The eeprom is a 93C76 smd Model... I would very much appreciate if anyone could help me understand the problem and possibly find any solution.
P.S : i have ordered some blank eeproms from the internet already.
M1DJF Posted - 05/01/2013 : 06:18:36
Provide me with make model and year of make than I will check if I have dump for the eprom
ZLM Posted - 12/16/2012 : 17:29:21
The chip may has other data related to other meters.
You need a original data copy to restore it.
