 GQ-4X not burning AT27C256R OTP
Necrosaro420 Posted - 10/22/2013 : 12:27:25
They act like they are starting to burn, go to 1% and quit. But then I do a blank check, and they still show as blank?
ZLM Posted - 05/05/2014 : 10:47:55
There is a speed setting area on the right software panel. From -2 to +2
briank9803 Posted - 05/02/2014 : 14:52:16
How do you set speed with software 6.29 GQ-4X? I'm having a similar problem.
ZLM Posted - 11/06/2013 : 14:46:18
There are many other users used this programmer to program AT27C256R, and no problem reported. That means the software should OK.
Did you try differenr speed? The chip also can be programmed with regular standard 27C256 device type.
Necrosaro420 Posted - 10/27/2013 : 13:01:13
Device ID: 1E8C, Atmel, Type: AT27C256R
ZLM Posted - 10/27/2013 : 11:27:50
Can you ID the chip? IF you can not ID the chip, then it maybe related to the pin contacting OR chip itself.
Necrosaro420 Posted - 10/24/2013 : 20:12:48
Any ideas?
