 ls the f80-7hcp is readable with GQ-4x
Mr-B Posted - 06/05/2014 : 15:05:36
hi everybody
I have just received my programmer today GQ-4x the reason for buying this was to reprogram bios chips on laptops as I own a computer repair shop.
so first chip I took is from a Toshiba a300d, after great effort I managed to read the numbers on this chip which were F80-7HCP.
To my disappointment there was no match for this chip in the device so I could not go any further .. so take another Mb which was an Acer locate the bios chip read the number and to my supprice it was same again , I only reason for buying this is so I can fix laptop MB I know all of them will not have same chip as I have already tested a few winbond chips with no problems.
so my question is the F80-7HCP readable with GQ-4x?
And if not is it possible add it to the device as I think I will be working this chip quit a lot.
thank you
ZLM Posted - 06/07/2014 : 21:01:21
The latest laptop bios file should get from the mother board manufacture website.
Mr-B Posted - 06/06/2014 : 05:58:02
hi
thank you for your reply I have I did what you said and have managed to read the chip .
so am I correct in thinking as I have managed to read the chip there I should have no problems in writing the bios to it.
also please could you advice as where would the best place to look for laptop bios files .
once again thank you for your help.
ZLM Posted - 06/05/2014 : 19:41:01
F80-7HCP is not standard chip manufacture part number. This is why it is not in the supported list. But I think there is a great chance to read and write with the GQ-4X.
Try to select the EN25F80 from the software and see if it can get the chip ID correctly.
