 29f016 tsop48
dgdiniz Posted - 10/19/2015 : 14:41:19
Hi, I have a Gq-4x and I have the adapter (ADP-077 and ADP-082) to program the 29f016/32 Tsop40 chips.
This adapter supports Tsop48 chips, so can I program a 29f016 tsop48 using the Gq-4x?
Seems that the only difference between the Tsop48 and Tsop40 are four pairs of NC pins in each corner of the chip.
So, it's possible?
ZLM Posted - 07/03/2018 : 14:45:41
This TSOP48 chip is not tested on GQ-4x.
Checked datasheet and found this TSOP48 chip pinout is not the standard. So, there is no adapter for it.
see:
AM29F016B TSOP48 pinout:
97886 bytes
nikos Posted - 07/03/2018 : 02:49:20
the software does not have any option for 29F016 TSOP48
ZLM Posted - 07/01/2018 : 07:44:13
If your chip is 40 pin TSOP, then you need ADP-082 base.
If your chip is 48 pin TSOP, then you need ADP-072 base.
nikos Posted - 06/29/2018 : 08:53:34
i have ADP-077 and ADP-072 not ADP-082.
anniel Posted - 06/29/2018 : 06:30:14
Originally posted by nikos
Originally posted by zzattack
Yes, align them like this:
hxxp://files.zzattack.org/img/upload/20102015-00184.jpg
i want to read 29F016 TSOP 48 i have adapter
AD-077 only do i need also ADP-082 adapter?
Regards.
Yes you need a base board.
nikos Posted - 06/29/2018 : 00:59:19
ADP-077 only do i need also ADP-082 adapter?
Regards.
zzattack Posted - 10/19/2015 : 23:03:04
