 Reduce mileage with GQ-4X
helderchissano Posted - 07/12/2011 : 04:54:24
Hello friend I wonder if there is a manual that explains how to use the GQ-4X to reduce mileage vehicles that use chips like 93c46 because I bought this stuff because I saw that had this option to reduce the mileage of a car would appreciate help because I bought it because of mileage.
ZLM Posted - 08/10/2011 : 09:23:01
MCUamll does not provide those information. You need to find this information from somewhere else.
helderchissano Posted - 08/09/2011 : 04:18:16
osvaldo Posted - 07/26/2011 : 21:04:06
You what that response is to modify the cuentaquilómetros of self that is done with a soft for that. Such a soft does is give you a chart on the PC of each part of the dashboard of a vehicle and it is this chart tells you what res you who do, the program modifies the data in memory that has the tableA if you got any questions ask me or add me to MSN from now thanks
M1DJF Posted - 07/17/2011 : 05:52:04
Hi
You will need to learn to work with bin and hex files and understand them as programmer will program what you tell it to program.
If you search the net more info is available but you will need to do some home work as no one will give it to you on a plate.
ZLM Posted - 07/13/2011 : 08:56:40
The GQ-4X programmer works like dummy. It only do the job read the data out of the chip and write the data into the chip. so, you need to understand the 93c46 data format once you read it out by GQ-4X, and then you change the data and then let GQ-4X write the data back into the chip. There is no manual for how to change the mileage. But there is a topic talk about how to remove the chip from the PCB.
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=2849
