 How to flash S25FL064A (FL064PIF)?
Dmitriy Posted - 04/28/2014 : 05:07:47
64 Megabit CMOS 3.0 Volt Flash Memory with 50MHz SPI (Serial Peripheral Interface) Bus
Datasheet www.spansion.com/Support/Datasheets/S25FL064A_00.pdf" target="_blank">h p://www.spansion.com/Support/Datasheets/S25FL064A_00.pdf
I have GQ-4X and adapter SOIC28. And I not found support for this flash in Device list (but in this page it is there www.mcumall.com/comersus/store/mcumall_willemsupportICs.asp" target="_blank">h p://www.mcumall.com/comersus/store/mcumall_willemsupportICs.asp).
ZLM Posted - 05/05/2014 : 11:46:41
Good try.
Add a adapter information in the device line may be a good idea:
Name="S25FL064*SOIC16",ID="010216",Class="W25X10",Category="SERIAL_EPROM",MFG="Spansion",Vcc="3.6V",CodeSize="8388608",Platform="GQ-4X",Adapter="SOIC16 to DIP8";
Dmitriy Posted - 05/02/2014 : 11:53:33
Tnx for reply... Good support.
Answer itself.
I'm added the line to devices.txt and using for that adapter SOP16 to DIP8
Name="S25FL064*SOIC16",ID="010216",Class="W25X10",Category="SERIAL_EPROM",MFG="Spansion",Vcc="3.6V",CodeSize="8388608",Platform="GQ-4X";
