T O P I C R E V I E W
laptech
Posted - 01/16/2015 : 03:37:33 Hello,
I need some help in making a new entry in the devices list so I can program a GigaDevice serial flash chip GD25Q80BSIG as my GQ-4X does not support that device. I have got numerous HP motherboards with that chip on them that i need to reprogram. I have attached a picture of the chip in question.
Posted - 01/26/2015 : 08:54:44 Many thanks for your help. I was able to use the info you provided and with an accompanying data sheet I was able to set up it's sister chip, the 25Q32BSIG. Both work fine. Again, many thanks.
Roger
Posted - 01/23/2015 : 20:00:17 Add following line into devices.txt:
