 GQ-4X DS2431 help
webgas Posted - 07/30/2015 : 03:34:45
With the recent update is available the use of this EEPROM DS2431,
I tried to read different in my possession is the hexadecimal result is: 1F or 2F or 3F etc ... i believe correct.
Question how do I write it? after several attempts I always get verify failed and the EEPROM is not just written !!!
psgama Posted - 03/13/2018 : 09:38:39
Has this chip been supported yet?
psgama Posted - 06/23/2016 : 16:08:18
Any progress with the DS2431? It is not showing up on the supported device list, although it shows in the text based device file in the program folder.
webgas Posted - 11/18/2015 : 11:57:59
I confirm the failure with the software 6.38
the reading is incorrect, any data(FF or 00) is contained in the chip, I find myself always 1F read.
openprogrammer works with these chips :(
ZLM Posted - 08/07/2015 : 07:15:30
Checked this DS2431.
It is not fully supported yet, it is under testing. The read/write are not fully tested. It still need sometimes to finish the testing.
webgas Posted - 08/07/2015 : 04:40:47
DS2431 is supported on the device "GQ-4X" from software version 6:36:
http://www.mcumall.com/comersus/store/mcumall_TrueUSBWillemsupportICs.asp
perhaps it is still in testing?
I consider all my reading not correct?
to let me know when you can work well with one wire protocol EEPROM, or I'll have to buy another programmer for these EEPROM.
ZLM Posted - 08/02/2015 : 17:31:01
The DS2431 is one wire protocol EEPROM. It is not in the supported list yet. It will be added later.
