 balnk
ianlill Posted - 12/12/2018 : 11:58:48
i keep getting this message no matter what i do have tried 2 ecu same problem device blank check failed at address 0x0000 10 read =0x05 can you help
31   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 01/03/2019 : 11:14:26
Originally posted by ianlill
all ok on continuity check
Do an Hardware I/O Diagnostics on your GQ-4X4 to rule it out.
ianlill Posted - 01/03/2019 : 10:47:36
anniel Posted - 01/03/2019 : 10:15:39
Failed,address =0x000000,devise=oxFF,buffer=ox12 WHAT IS THAT TELLING ME so i can understand
It is telling you just that. Your write failed at address 0x000000, the device reads 0xFF and the buffer is 0x12.
anniel Posted - 01/03/2019 : 10:11:27
DONE THAT NO 5 VOLTS ON CLIP
You are not looking for 5V. You need to do a continuity check. What make and model is your multimeter?
ianlill Posted - 01/03/2019 : 09:59:58
ianlill Posted - 01/03/2019 : 09:57:23
anniel Posted - 01/03/2019 : 09:30:10
how do you do that
Multimeter.
ianlill Posted - 01/03/2019 : 09:24:42
how do you do that
anniel Posted - 01/03/2019 : 09:17:59
it is done via a clip that goes on the chip
Did you test for good continuity from chip to ZIF?
ianlill Posted - 01/03/2019 : 09:14:50
anniel Posted - 01/03/2019 : 09:10:15
same problem
Is this a DIP or does it need an adapter?
ianlill Posted - 01/03/2019 : 09:07:32
same problem
anniel Posted - 01/03/2019 : 09:03:22
no its on my ecu what is it telling me when i get Failed,address =0x000000,devise=oxFF,buffer=ox12
Ok, pull the chip off the board and try again.
ianlill Posted - 01/03/2019 : 08:59:54
anniel Posted - 01/03/2019 : 08:51:21
Sorry its M95040
Is it pulled off the board?
ianlill Posted - 01/03/2019 : 08:47:57
Sorry its M95040
anniel Posted - 01/03/2019 : 08:43:00
used M95040 it blanks,go to write then get the Failed,address =0x000000,devise=oxFF,buffer=ox12
Is your device a M95404 like you said earlier or a M95040?
ianlill Posted - 01/03/2019 : 08:35:18
anniel Posted - 01/03/2019 : 08:28:51
gq-4x4
Ok and which part number did you use in the device list?
ianlill Posted - 01/03/2019 : 08:24:12
gq-4x4
anniel Posted - 01/03/2019 : 07:14:24
do you mean this number m95404
What programmer do you use?
ianlill Posted - 01/03/2019 : 07:03:34
anniel Posted - 01/03/2019 : 06:54:12
yes
What is the part number?
ianlill Posted - 01/03/2019 : 00:40:10
yes
anniel Posted - 01/02/2019 : 16:01:17
failed,address =0x000000,devise=oxFF,buffer=ox12
get the above
Probably damaged. Did you use the same part number in the device list?
ianlill Posted - 01/02/2019 : 12:58:11
get the above
anniel Posted - 01/02/2019 : 12:41:52
its blanked but wont write
So now they pass the blank check but simply refuse to write? Do you get an error message?
ianlill Posted - 01/02/2019 : 12:24:42
anniel Posted - 01/02/2019 : 12:04:49
yes wont write
If your devices doesn't pass the blank check they are not erased correctly or damaged.
ianlill Posted - 01/02/2019 : 11:50:29
yes wont write
anniel Posted - 12/13/2018 : 04:30:41
Did you erase them?
