 need help to buy a programmer
vari21 Posted - 04/14/2020 : 16:51:03
hi, i want a buy a new willem pcb programmer to write succesfully 27C322 27C160 27C400 27C800 eproms for my megadrive games, i still have an old win98 computer with lpt port,db25 printer cables, external 15v 4A power supply,16 bit 42pin adapter ive got software 098 097ja ..
the problem is i dont know what willem hardware pcb which will works well with my project.i use to have a willem pcb 5.0E but i ve never was able to write anything with it it gave me buffer underun each time i want to write a rom on the eprom. so may be changing a version hardware pcb T or C will would be a solution i need your opinions thanks.
22   L A T E S T    R E P L I E S    (Newest First)
vari21 Posted - 04/25/2020 : 05:17:40
hello again i need your expert advices please.
i m about to order the gq-4x+adp054 from datahardware ebay.co.Uk
i made a lot of searches and i found that datahrdware is the official supplier distributor of mcumall products in uk,so all their products are genuine.
the problem is a lot of people have troubles with programming the 27C322/27C160/27C400/27C800 it seems that the programmer was nt reliable what do you think thanks.
anniel Posted - 04/19/2020 : 06:14:48
Originally posted by vari21
my budget is 30 euro i know it s very low for a good programmer that s why i went with willems burner,sorry i need also to burn old eproms that requires 21v vpp from time to time,i did nt mention that in my previous message sorry.
I think you have no other choices than Chinese junk or look for an used programmer of good quality. You can maybe repair the defective one you already have.
vari21 Posted - 04/19/2020 : 04:37:21
anniel Posted - 04/18/2020 : 08:48:49
im talking about the chinese programmer which i suspect faulty? yes defintely you right modern burner is the way to go. in my case need to burn 27C322 /27C160 /27C400 eproms for megadrive projects, which programmer do you recommend?
What is your budget?
vari21 Posted - 04/18/2020 : 04:08:24
anniel Posted - 04/17/2020 : 13:26:40
i think the chinese device is faulty i got it from ebay .thats why i want get another pcb version much improved.
the willem software version 0.97e has support for 27C322 27C160 eproms can anybody confirm that?
Are you talking about the programmer or the chip that comes from eBay?
If you want improvement go with a modern programmer.
Simplest is to install the software and check it out.
vari21 Posted - 04/17/2020 : 13:14:28
anniel Posted - 04/17/2020 : 06:30:47
i ve tried 3 IEEE cables the thciker,the ones we use for old printers, yes lpt is working properly, i have hardware present when i plug a 12V 3A dc psu i can read a chip verify it but no writing at all, when i keep jumper8 on 5.7v position to start programming the process goes the end but in order to have the green bar i get the error.
when i remove the jumper8 to allow 6.2v since the 27C322 need 6.2v, i get hardware not present as soon as i click on program icon very strange.
If voltages are good at all times, I can't see why you get that error.
vari21 Posted - 04/17/2020 : 03:16:16
anniel Posted - 04/16/2020 : 16:18:44
yes 5v very stable.
Certain about your LPT working correctly? Did you manage to write some other chips?
vari21 Posted - 04/16/2020 : 13:58:39
yes 5v very stable.
anniel Posted - 04/16/2020 : 12:41:10
Yes when i check with the multimeter 6.25 is present on pin 17
And logic keeps a good constant 5V?
vari21 Posted - 04/16/2020 : 10:05:17
anniel Posted - 04/16/2020 : 09:56:27
please help me
i get hardware not present error when jumper 8 is removed to
start programming the 27C322 eprom which needs 6.25v to be programmed ?
also i want know the difference between willem hardware pcb5.0E pcb5.0T pcb5.0F i want to buy a new willem pcb
programmer so i want to make sure which version will work reliably with 16 bit 42pin eproms like the 27C322
Does the 6.25V go to the chip?
anniel Posted - 04/16/2020 : 09:56:02
ok i will check that.
sorry i ve got another questions so excuse my ignorance.
why i get hardware not present error when jumper 8 is removed to
what the difference between willem hardware pcb5.0E pcb5.0T pcb5.0F i want to buy a new willem pcb
For the differences between each versions ask the seller. Also ask for a supported devices list.
vari21 Posted - 04/16/2020 : 00:44:29
please help me
vari21 Posted - 04/15/2020 : 09:31:09
anniel Posted - 04/15/2020 : 09:02:17
i ve modified the twc/twe i put to many values there no succes, i ve tried almost everything without succes
increasing the buffer i dont think i ve done it. how to do that?
Read your Windows 98 documentation.
vari21 Posted - 04/15/2020 : 08:13:07
anniel Posted - 04/15/2020 : 07:49:02
hi anniel
you said setup didnt push data fast to the programmer, so how to fix that by modify twe/twc in the software
or replacing the power supply or what?
Did you try increasing the buffer size?
vari21 Posted - 04/15/2020 : 07:16:02
hi anniel
anniel Posted - 04/15/2020 : 06:11:02
A buffer underrun indicates your setup didn't push data fast enough to the programmer.
