 issue with driver install Win7
mgrt Posted - 03/07/2017 : 21:23:44
i got software and driver installed on winXP, device works just fine.
but when i try install on Win7-32bit doesn't work, device manager can't recognize programmer but when i try to update driver it tells me driver all good and no need to update. and doesn't let me install/update driver. got latest driver and soft.
what I'm doing wrong?
Download Attachment:
89225
110325
mgrt Posted - 03/10/2017 : 17:23:46
software can't find programmer.
also no any driver was ever installed, are you saying that this programmer could work without any driver at all.
ZLM Posted - 03/10/2017 : 00:39:14
The cypress fx2l is OK. That is the original device string from the USB chip.
As long as your device manger recognize the programmer, then the software should find it.
Both GQ USB programmer and Cypress Fx2L should work.
anniel Posted - 03/08/2017 : 13:34:48
Try support@mcumall.com
mgrt Posted - 03/08/2017 : 13:09:59
in a main page of device manager where you can see all devices it called "unknown device" but when i try to update drive after update fails you can see name cypress.
also in properties of device, tab driver i can see "driver provider"-cypress
anniel Posted - 03/08/2017 : 11:51:48
The device manager sees the GQ-4X as "unknown device" or Cypress FX2LP?
mgrt Posted - 03/08/2017 : 11:20:06
not good, software can't see programmer - "did not get response from programmer"
device manager can see this device as "unknown device" and offers to reinstall driver. but when i try to reinstall it tells me "best driver software for your device is already installed" and it goes like this in loops.
anniel Posted - 03/08/2017 : 10:07:03
look at reply #5 here; http://www.mcumall.com/forum/topic.asp?TOPIC_ID=6920&SearchTerms=CypressFX2LP
mgrt Posted - 03/08/2017 : 09:56:01
yes i checked that manual before, did everything as it says, and after i click "next" on a picture 3 i get message "best driver software for your device is already installed, windows has determined the driver software for your device is up to date, CypressFX2LP no eeprom device"
anniel Posted - 03/08/2017 : 07:45:09
Have a look here.
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=7054
mgrt Posted - 03/08/2017 : 07:37:21
i have qx-4x4 and latest driver from website for win7-32, windows recognizes device as some kind of cypress fx2lp. when i manual select driver to update i get message "best driver software for your device is already installed"
i try to install on a computer with fresh windows install with no other software except VMware workstation and Hantek oscilloscope, do i get driver conflict with hantek?
i don't know why i cant upload pictures, maybe i don't have enough posts.
anniel Posted - 03/08/2017 : 03:58:05
Your attachments doesn't work. Which version of the GQ do you have and which of the drivers did you try.
